How to make the 'Invert Phase' as default?
Hello Dustin,
I have a question about why my Premier dac (from 2019) suddenly has decided to remain in position with inverted phase despite that I power off the dac when going to bed.
After firmware upgrade, inverted phase is no longer possible to save. But today the dac started up with inverted phase on, and I tried to power off the dac a couple of times without leave the inverted phase setting; the dac still start in inverted phase mode!
For me this is not a problem since I have always used the dac in inverted phase mode (I have Burmester 911 mk3 ), but I am curious about what happened.
To be clear, after the firmware upgrade I had to manually press the inverted phase button after every new start, but now the dac seems to be stuck in inverted phase when restarting.
Interesting. This shouldn’t happen. I’m working on new code for the Discrete and Premier now so I’ll check on this.
If you want to try and fix it, can you turn off phase invert and perform a reset in the menu. After you reset in the menu make sure to exit the menu (this is when it saves the settings) and restart the DAC. Is it back to normal?
Thank you Jonathan, I will try this and come back later.
Yes! It is back to normal​:blush:
Thank you!
