The Sentinel DAC - State of Production
As we approach the end of 2025, I wanted to post an update on the current state of production for the Sentinel DAC. We have many preorders and folks excited to get their hands on one. It won’t be too long before that happens!
Final production was locked in at the end of September, but the actual production of PCB’s and metal components started many months before. We have completed production for many of the Analog Converter and Digital Director assemblies. The last remaining parts are from the Power Supply, which was designed with the specific measured values for the final working Analog Converter. No guesswork.
The scale of the product has been staggering, with 56 individual PCB’s and 125 CNC Machined parts (not including custom CNC hardware, of which there is plenty). Approaching a project of this size requires extreme attention to part management, quality control, and inventory.
Finished Casework should start trickling in from the anodizer allowing the very first founder edition units to enter final production. Shipping to start in January.
Below are some snapshots of the current Sentinel production. Highlighting some of the craftsmanship that is going into making this product a reality. After more than a decade honing my design skills and practicing the craft of CNC machining, we are able to deliver an industry leading experience in all regards.
I hope you enjoy,
Dan Francis
Note: you can click to enlarge these photos to see more detail :+1:
Sentinel Update - Dec16th2025-34
Sentinel Cover Plates
A pallet of Sentinel covers part way through production. The first operation has been completed and they are waiting for the final 5-axis finishing work from our Grob Horizontal CNC mill.
Sentinel Update - Dec16th2025-35
Sentinel Heatsinks
Each of these heatsinks has an immensely time consuming process to create the individual heatsink slots. More time consuming than typical extruded heatsinks, but well worth the effort for the fit and finish we are able to achieve.
Sentinel Update - Dec16th2025-33
Sentinel Basemetal
Sculpted basemetal can be seen here for the Analog converter. Even the underside of the Sentinel gets beautifully CNC machined finishes and details.
Sentinel Update - Dec16th2025-04
Sentinel Clock Base Plate
The Sentinel Clock parts are machined with CNC textures and fine detailed chamfers as they will be directly alodined. There is no sanding or beadblast to cover up handling or material blemishes. Every detail must be preserved from the moment they leave the machine.
Sentinel Update - Dec16th2025-30
Sentinel Clock Oven Cover
The large crystal ovens that will be used for the Sentinel Femto Clock.
Sentinel Power Base Display - Colors
Sentinel Powerbase Display
A bit of an explanation, but something I am really happy with how it turned out. On the Sentinel Powerbase, we CNC cut a small blank of what we call black/white acrylic. This is unlike typical displays that use white acrylic with a back light. Under bright lighting conditions, generic white acrylic can be hard to tell whether the unit is on or off. But, with black/white acrylic the powered on versus off condition is clear as day. The above photo shows no AC (Left), on (Center), with AC but powered off (right)
Sentinel Update - Dec16th2025-07
MSB Logo Detail
Another great detail we worked into the MSB logo is suspending the center of the ‘B’. Supported by small tabs, they will go through the bead blast and anodizing processes. This makes a perfect color match for later when they are removed and inserted into the badge. A small detail, but clever implementation.
Sentinel Update - Dec16th2025-37
MSB Logo Sentinel Converter Insert
These stainless MSB badges are machined in-house, with a 0.02” (0.5mm) Endmill! The micro milling detail is hard to see with the naked eye.
Sentinel Update - Dec16th2025-01
Sentinel Update - Dec16th2025-39
The Sentinel Badge Pocket and Insert
The Sentinel Stainless Badge will be inserted into the faceplates as seen here. Adding a refined accent.
Sentinel Update - Dec16th2025-11
Sentinel Converter Faceplate - Grob Operation 1: for the Analog Converter Faceplate. These complex CNC parts require 5-axis machines with the most advanced CAM software to drive them.
Sentinel Update - Dec16th2025-15
Sentinel Converter Faceplate - Grob Operation 2: for the Analog Converter Faceplate. Using the advanced CAM software results in truly industry leading finishes that require no hand work or sanding to prepare for finishing.
Sentinel Update - Dec16th2025-21
Sentinel Preamp Boards
The SMT department has been busy for months with some of the most complex builds yet. What can be seen here is the Sentinel Preamp. One of these is paired with each mono DAC.
Sentinel Update - Dec16th2025-27
Cascade - Sentinel Comparison
Here is a side by side with the Cascade DAC. The complete Sentinel DAC system that has been playing in the MSB listening room. It has been an experience unlike anything before it, and we are so excited to start sharing this new level of musicality with you.
art, science, and audio merge
Also, a great breakdown on some of the tech an architecture of the Sentinel DAC if you missed it:
Art, science, and audio merge perfectly.
Absolutely incredible!
Absolutely stunning, congrats MSB Team!
You guys deserve a ton of recognition on your culture. What I mean by that is your mature approach to experiment in to order to push the boundaries of what’s possible. Furthermore, your very intentional focus on quality (end to end), inventory management and customer support.
Certainly makes me proud to be an MSB DAC owner!
Dear MSB Team,
I’m overwhelmed with the level of detail, the astonishing look and with the limitless craftsmanship. One can only mention superlatives. What comes to mind is a quote of John Coltrane. If you will pls, let me share it with you;
“There is never any end. There are always new sounds to imagine; new feelings to get at. And always, there is the need to keep purifying these feelings and sounds so that we can really see what we’ve discovered in its pure state. So that we can see more and more clearly what we are. In that way, we can give to those who listen the essence, the best of what we are. But to do that at each stage, we have to keep on cleaning the mirror.”
PS. Lottery tickets are bought, the draw is this evening, fingers are crossed :crossed_fingers: :smiley: :+1:
stand in line please
:rofl: , let’s split :wink:
The Cascade looks tiny in comparison :grimacing:. I noted the gorgeous flag ship HRS racks also. May I ask what shelf spacings are used? Plenty ventilation is needed for the Sentinel units as I understand.
The bottom opening from shelf to shelf is just shy of 15 inches (381mm) and the opening for the middlle shelf is just over 15.25 inches (388mm).
The Top and middle shelves are mounted slightly lower than centered on the markings on the front of the rack legs.
And the bottom shelf is as low as it can go.
Mike over at HRS set up the rack specifically for the Sentinel DAC. He will know the specs, spacings, and weight for any inquiries. We are very happy with the ventilation and spacing of the rack as seen in the listening room. And yes, it dwarfs the Cascade :smiley:
Thanks @Eric1 ! We will keep on doing the good work! In our estimation, there is always more to uncover and discover. That is what keeps this line of work interesting. Thanks everyone for the support over the years!
