Hello all! Good progress has been made on the Sentinel. We have completed a preliminary revised “core” design. This brings us to the second round of prototyping and testing. We will now begin working on the PCB’s and building out these modules. We don’t invest in final designs until we have actual testing and listening feedback. Over committing would compromise our ability to further update and change the designs as needed. Flexibility is key when pushing the limits and looking for unprecedented performance.
What can be seen here is the central power distribution module. This is a multi-layered stack up that takes the incoming DC power from the powerbase and delivers it to both the Right and Left Mono DAC modules and the clock circuitry. You may also notice each mono DAC has been updated from an assembly of parts to individual unibody designs. The original design was made before we had our new 5-axis Grob machining center, so this new design will take full advantage of our new manufacturing abilities.
Looking at the jackpanel, the bottom center through hole represents the incoming DC umbilical linking to the Sentinel Powerbase. On each mono DAC, the rectangular socket will be the dedicated fiber input coming from the Sentinel Digital Director. Above and below the fiber connections are 2 XLR and 2 RCA analog inputs. Closer to the center, we have two XLR outputs per channel. And between those… is an experimental proprietary link for the Sentinel Edition M500’s. More on that coming after testing!
And here is the heart of the system. I won’t say much at this stage, but what you can see is dedicated circuits for both the 44 and 48 (and their multiples) playback. Each crystal is in a removeable ovenized chamber. The clock module is floating on an isolated platform. Using cable isolators, energy in and out of the system is dissipated into heat as the ultra fine fibers rub together. Since the crystal itself is a mechanical part by its nature, we have found measurable improvements by isolating this clock circuitry from unwanted inputs and vibration.
The road ahead is still quite long, but we are having the time of our lives on this one! As always, everything shared here is subject to change. Please stay tuned for future updates as continue our work.
