I’m sure installation of a Sentinel DAC would have easily qualified as one of the ancient Twelve Labors of Hercules. The amazing team from Suncoast Audio made short work of the task. My elevator did it’s part also. From the packaging all the way to the finish on the parts, this product exudes quality. It is burning in now silently. I can’t wait to take it for a spin later today. Great job MSB. I’ve had multiple MSB DAC’s over the years but I believe this one will be something special.
Hi Cincy2
Looks great!
Suncoast will be doing a Sentinel install at my place later this month. Mike has a great team there.
I see Odin2 speaker cables. What are you using for XLRs?
Hi Dan,
Odin 2 XLR.
Regards
Eric
@Cincy2 please keep us posted, did you upgrade from a Cascade and what if anyting are you using as a transport
Changed from CH Precision C10 to Sentinel. No transport, PInk Faun Dual Ultra with MSB ProISL link.
Thanks for the many years of support Eric! I am sure you will be rewarded with musicality only the Sentinel DAC can produce. Please enjoy for many days to come. What a treat, we are all looking forward to hearing your review as you burn in and get to know the sound of the Sentinel DAC. Cheers!
@Cincy2 thank you
Congratulations, it is an absolute reference and a musical bliss to enjoy every day. Happy listening
I share your excitement, Eric!
Note that it takes at least three days of burn-in for the Sentinel to perform properly, and that it will slowly improve thereafter.
Even though my previous Cascade was a fantastic DAC, the Sentinel is no doubt a superior DAC, as anyone would recognize immediately. At the top level, my experience is that all DACs sound very good, but I do not believe that any competing DAC would give the same emotional engagement as the Sentinel. The dense, ultra-lifelike sound without any harshness and tangible soundstage is addictive.
@Cincy2 . Thanks. Was it a full mono C10 with T10 and C10 conductor?
Congratulations Eric! I’m sure the system sounds amazing! Enjoy in good health.
Mike (Ritmo)
Yes. Full Mono wqith T10 and Conductor. It was an amazing setup.
Would it be fair to speculate that the vast majority of amplifier and speaker combinations currently on the market are incapable of showing the full performance potential of the Sentinel DAC due to their relatively high self-noise and/or limited resolving capabilities?
Would this also be the case for the Palisade and Cascade DACs?
Is MSB Technology so far advanced that none of us have yet discovered their limits of realism?
I would say that your theory applies to any audio component in a system. It is only as good as the weakest link.
Cincy
I think speakers are the biggest limiting factor these days. There are preamps and power amplifiers on the market that measure essentially perfect with no audible noise or distortion.
Indeed, most speakers have one or more orders of magnitude higher distortion than any amplifier, let alone an MSB DAC from the past 10-15 years. And that’s before one puts them in a room.
The fact that we can hear significant sonic improvements between Discrete, Premier, Reference, Select, Palisade, Cascade and Sentinel DACs suggests there is something beyond beyond the noise floor limit of a system (not simply more resolution) that contributes to a more realistic portrayal of acoustic instruments and voice.
Presumably, the Sentinel amplifiers are designed to remove another veil from the Sentinel DAC, but we are still stuck with complex and lossy passive crossovers in speakers which vary with playback level and where passive components may have 5% tolerance on values.
