I noticed these settings on the USB driver application for windows. What’s the optimal setting for a Windows PC using JPLAY to a Discrete DAC?
Thanks, Ian
I would leave it as default (should be 512x samples). You can try changing it if you are having issues.
Will do. What are the issues?
None that I know of, but in the early days of USB audio some computers had processing problems and dropouts. I don’t think that’s the case these days.
