Check about the work rates of USB V2 input module
May I check if the USB (not ProUSB) input V2 works at rates up to 24/384kHz and 8xDSD, which means this module supports DSD 512 format?
I checked in the MSB official webpage and it says USB input only works at 4xDSD. But it seems that is the earlier version, rather than V2 which is not mentioned.
So may I check the rates of USB V2 input module? Is it the same as the new I2S HDMI one?
Thanks.
The V2 version of the MQA USB module will work at 8xDSD and 24/768kHz.
The V2 version has this change along with small changes to reduce some ticks/pops with certain servers.
Thank you.
@Jonathan_Gullman Hi Jonathan re the ticks/pops. On top of what we talked about already, I have recently been experiencing some also when switching from one track to another whilst a track is still playing: using iPad > Roon > Pink Faun 2.16 > Reference DAC. So is that normal (I was talking to Paul about it and he thinks I may also have some earthing issue)?
@Lu62 I would expect this behavior depending on where in the song the player is and if the sample-rate/format changes. Is it going from DSD to PCM, MQA? Etc…
