Pro-isl error
hi
i have the reference dac+director and i see an error in the pro-isl from time to time.
what could be the problem?
thank you
Most likely the error is going to be a bad fiber connection. The ProISL error will show up if there are too many errors in a certain time frame.
If changing the fiber cable doesn’t fix the problem, try a new set of SFP modules. You dealer should be able to get them for you no problem or you can message me directly and I can help get them to you.
