MSB Select DAC Input and Output Issues
Hello everyone,
I’m a long time MSB user and I recently discovered that my MSB Select DAC input signal is abnormal.The Select DAC has no input or output when it is first time turned on each day.
The screen display “RCA - -” , “XLR, - -”,No sampling rate figure is displayed.
However, both my dCS Rossini CD transport and Antipodes K50 are working,If you restart the Select DAC at this point, everything will return to normal.
BTW,The input signal is not currently detected and switched automatically.I’ve check the option in the DAC menu, that’s the “Auto with switch”, default option from Factory.This is my second Select DAC,I remember the first set of select DACs worked perfectly and these issues didn’t exist.I just updated the firmware to the latest version 39.21, but issued is still.
Has anyone else experienced this while using it? Thanks
Frank
Hello @Frank_Lee
Can you email me a video of this issue? It’s not something I’m aware of.
Jonathan
Will do,Thanks Jonathan.
@Jonathan_Gullman Hello Jonathan,I’ve upgraded the firmware again and power off the Select DAC, Remove the power cable and waiting for few minutes then restart it.
Currently, The issue has been solved.When the Select DAC power on and the screen display the input sampling rate, RCA/XLR/Renderer v2 all of normal.
Sorry for that, thanks!
