Cascade stuck on input
hello all
i have cascade dac and sometime after few hours
the input is stuck and only after restart i can change
input.
it’s happening a lot.
what’s wrong?
thank you
Please send me a email and I’ll get you some new code to test if you don’t mind. I’m at the 99% point for a new firmware release.
ok send me the code.
thank you
ofer
בתאריך יום ד׳, 24 בספט׳ 2025, 4:06, מאת Jonathan Gullman via MSB Technology | Forum ‏<notifications@msbtechnology.discoursemail.com>:
it’s not only the input, the remote doesn’t respond until i restart.
i think it’s a bug and you should fix it.
thank you
I am confident they will fix your issue. :wink:
i hope the new firmware update will come out
soon.
I have already been using it, your issue is indeed solved! Just putting it through final testing before public release. Probably by tomorrow :+1:
thank you
For anyone that doesn’t want to wait for the public release on our website, you can download and early copy here:
https://drive.google.com/file/d/1nAe9wlXz5tMRRP_A3PF6pgGpC0_ig95_/view?usp=share_link
I only ask that you share any feedback with the update process. It’s been going through a lot of testing and it’s fixed all the bugs that have been reported.
Well it worked. 1.9.1.1, What goodies did I get.
The new code is vastly more stable and it adds more I2S via HDMI sources. I wish I could tell you it added the ability to stop time or make you a coffee, but for now it just works better :slight_smile:
hi
after the firmware update the cascade is acting weird.
while i am watching tv on the analog bypass the dac restart by itself to the xlr input and stuck.
the update make it worse than before.
what’s going on here?
Please try the new firmware now avaialbe, it is a big overhaul and should have improvements:
