my Cascade remote yesterday started moving the volume very slowly when turn the dial. I assume it needs a battery replacement, I opened the back of the remote and there is a circuit board blocking things, before I did anything else wanted to ask, please advise
Plug the remote (bottom end) into a mico-usb cable then into a USB charger or USB port on a computer. Wait until the light goes from red to white ( a few hours). Your remote will be fully charged.
There is no need to disassemble the remote.
Thx will di
The remote also has an indicator LED. If it’s flashing white, it means the battery is good. If it flashes white/red, it means the battery is low and should be charged. If it flashes red, it will not work until the battery is charged.
