Is possible an additional prime DAC module on a discrete dac?
Hi. there.
I watched the video clip disassembling a discrete dac on youtube.
There are 4 prime DAC modules slots on the board, 1 and 3 slot inserted, and 2 and 4 slot empty.
Is possible an additional prime DAC modules on 2 and 4 slot?
If possible, is there a performance upgrade for dac function?
Thankyou
The Premier and Discrete DACs do share the same motherboard (which is why there is space for four DAC modules), but the rest of the circuitry, and even the DAC data format, is different (the empty DAC channels do not have any data or clocks flowing to them). If you plug in 4 modules into a Discrete DAC several reversible electrical faults will occur (like extreme DC offset on the outputs). The software will inform you of those faults and not allow playback.
Thankyou for your reply.
