I want to know how to control the Reclock on/off( Video Mode)I found that my DAC has no input audio delay, and I’m worried it might affect the sound quality.I bought an old aluminum MSB remote control, but I can’t control my DAC.Should I buy the new MSB remote to control my dac?
I’m not sure our metal remote can control an Analog DAC. The metal remote sends many instructions, such as volume, at a much higher rate than our older remotes. Jonathan may be able to answer that question.
As far as Video Mode you may or may not be able to tell that there is a latency difference. The video mode reduces latency, but the normal mode “may” already have low latency depending on the source/DAC clock misalignment. You may not hear the latency difference in certain circumstances.
@myy , we can absolutely help with that. Please submit a ticket to our support (link below) and we can get you the correct remote for the analog DAC. We have had several versions over the years and will need to set you up correctly.
