Power Management - cables
I just purchased the Shunyata Everest X power management and power cables - and have been really impressed with them. Just wondering what others use for power - thanks.
I run the analog side of my Cascade DAC to the Shunyata Denali V2 via Audioquest Firebird power cable and the DD is plugged into a dedicated PS Audio PowerPlant 12. Wanted to separate digital from analog components.
Per Vince’s instructions, I have two 20 amp circuits via 10 ga wire from a sub panel near the listening room. The amps are plugged directly into one circuit. All the rest of the gear is plugged into a Inakustik 3500P conditioner which is plugged into a Tripp Lite IS1000HG isolation transformer which is plugged into the other circuit. The isolation transformer reduces the EMI noise from 2000+ mV down to around 20 mV. I’m not sure where all the EMI is from - could be the inverters on our solar panels, but I don’t hear any noise through any of the gear.
