Jack's Place - Melco/MSB/Burmester/Wilson Audio
Using a modified Melco (with 2 x 4Tb SSD discs) as a source for all of my music, feeding into The Analog DAC which is directly connected to a Burmester 911 MK3 power amp. Speakers are Wilson Audion Sasha DAW.
Thanks for sharing! What are those speaker cables? I am trying to figure out what that conditioning block is? I am not familiar.
Those are MIT Oracle v2.1 cables.
Some updates. An Innuos Phoenix USB re-clocker was added in between the Melco and the Analog DAC. And the Melco, Innuos and MSB are now running on battery power from the Stromtank.
I know a lot folks here will say, the MSB can go straight to the power amp, I’ve decided to put a pre-amplifier to the mix. I’ve added a Burmester 808 MKIII to the setup, and in my setup it is a big improvement from having the Analog DAC go straight to the Burmester power-amp.
