I have my phono stage output connected to Sentinel analog input 2. Sentinel controls the volume.
When I mute the Sentinel and the record is still spinning, there is still output from the Sentinel. It is at a very low level and the level is not affected by the level setting.
Shouldn’t mute completely cut of the output of Sentinel? It did on Cascade.
I do have a different phono stage now, the VAC Statement, which, as luck would have it, replaced my previous phono stages at the same time I switched to Sentinel.
That could be the case, but I did not have this issue with Cascade. But, again the preamp part of Sentinel is, I think, different from that of Cascade.
Hey Dan, Just did the same test on my Cascade and I do not get a complete mute. Could still hear music playing from listening position. I have had this also happen on other amplifiers.
This is all by design! Not to worry. With an MSB amplifier, it will likely be 3-4 dB louder on the Sentinel DAC than when you had the Cascade DAC. We could disconnect completely, but when using analog inputs that may have a DC offset, reengaging the output can cause a loud pop. This is the best and safest experience for most of the time.
