Welcome and thanks for sharing @ASIO !
I see you are looking for an AES/EBU input, are you currently using the SPDIF coaxial with word sync enabled?
Yes I am , I was looking for some input if there even would be a advantage using AES vs
SPDIF ?
Yes, the AES is a much better connection. It is a superior technology over the typical coaxial cable. If your system is revealing enough, you will hear an SQ improvement. With the word sync connected, the AES input is often the preferred method of using the Aurender and has sometimes even been preferred over the Pro USB.
