Improvement using external clock Mutec Ref10
Ah, this is unique to wireless. My Apple TV is HDMI connected to my TV, which is TOSLink connected to my DAC. Thanks for the info though.
I have used YouTube via the AppleTV. Music is fine, best to leave “ video” mode off for the music, unless the lip sync issue is too bad for your sensibilities. Music better slaved to the MSC clock.
I would assume similar to a setup using PC to stream YouTube to the TV, and HDMI, or TOSLink, to the DAC in some fashion.
Again I ask, is the latency with video mode turned off constant or variable? If it varies, I won’t waist my time looking for a lipsync delay solution.
Constant.
Thank you Dustin. :smiley:
Sorry, I think there is some confusion with the question.
When in “video mode” the latency is constant.
When in normal playback mode and using S/PDIF the latency is variable. Its a dynamic buffer and it depends on if the incoming clock is faster/slower than the clock in the DAC.
