About discrete dac's analog out interface change(xlr->rca)
Hi.
I live in korea.
I want to change the discrete dac’s analog out interface change(xlr->rca) or buy xlr2rca apdatper, because my power amp has only rca input.
what is you prefer?
Do you have a program for it?
If possible, let me know to how do it.
Thankyou
For swapping the output, the best thing to do is get in touch with your dealer. They can get the output swapped for you.
Our XLR to RCA converters are the best option with a Premier DAC or higher-level DAC. This is because the converters need a DAC with a 150-ohm or lower output impedance.
I would wonder if its sound will be louder at a same volume when use the msb xlr-rca adapter? Tks
My guess would be the volume you hear will be more dependent on the different gain/input designs of a single-ended input vs a balanced input.
