My system home for now
Hello
My system.
Speaker
Yg vantage 2 under the speaker i use ISSB-40 Isolation Speaker Spike Bases from Graphite Audio.
AMP
MSB s202
Streamer
pink faun ultra 2,16 full loaded whit the new USB ultra card and 8 TB hdd
DAC
MSB premier dac whit premier Director.
Use a nordost qsource to power my qnet and my qpoint.
Gigawatt power strip PF-2 EVO.
Speaker cable Stealth Audio Cables
Dream V18-t
CIS-60 Cable Isolation Stands to the speaker cable.
Powercables Stealth Audio Cables
Dream 20 20 and Cloude Grande to the power strip and the qsource.
Lan cables is Stealth Audio Cables Ultimate
Interconnect Stealth Audio Cables
Sakra V17 Limited Edition
Power from power base to the dac is Level 3 from Farad.
USB cable is Stealth Audio USB Double Tune
News made this weekend.
doepke dfs2 audio install to my power for my set up it run in to a Gigawatt circuit breaker G-16A 1P and there are used Gigawatt cable LC-Y EVO 3X4 to the outlet Gigawatt G-044 SCHUKO DUPLEX
All so install a better lancable from fiberbox there go in the house to the set up a WireWorld Chroma Cat 8 20 meter
Rack
Bassocontinuo Ghironda 2.1 custom made whit alcantara and red stithes.
Turntable
dr. feickert analogue venti whit Ikada 9Gss Silver Coil pick up and Tonearm Ikeda IT-407CR1 there stand on Graphite Audio CLASSIC 100 ULTRA Isolation Platform.
dr feickert linear power supply upgrade.
Riaa
Gold note ph1000
Entreq Vibbeater on speaker, amp, streamer
On the way to be upgrade is
pre amp
acoustic
hope all so a new dac this year or next.
more info will come
Hi Henrik,
I’m considering upgrading my streamer and would like to know what you think of your Pink Faun.
How did you connect your pink faun streamer to the DAC? Can you stream DSD256 with the connection you are using?
Hi Dan
What streamer do you use now ?
Im very Happy whit my PF and i run it on network and i have testet usb and coax and network Sound the best in my system.
Where do you live ?
It can run all formats on network
Best regards
Henrik
Hi Henrik,
I have a Roon Nucleus Titan. I’m happy with it but always checking to see what else is around. I can stream DSD256 over the network. I’m adding a Pro USB to the Cascade… that should let me stream DSD512. PCM works too.
I’m Florida, USA, the most South Eastern part of the USA.
Henrik! Welcome to the forum, thanks for joining!
Do you have a render modul ?Dan
Yes, I do.
Try to run on network :smiley:
I’m moving to Pro USB for a couple of reasons. One is I want more isolation. The Pro USB runs at a higher data rate than the Render does. And lastly, I’m looking at rearranging some things and Pro USB gives me more flexibility.
Cool
MBS has done an outstanding job of making the Cascade noiseless. Even though I may be gilding the Lilly, I want to do what can to prevent any noise from being injected into it.
I have try that dac and bye fare the best dac i had in my hands for sure i want one later this year my self
Do try the Melco N1-S38 it will not disappoint.
Thx but i stay on my 34k € Pink Faun
