I am auditioning the XACT S1 EVO Music Server in my system right now. For context, my system comprises of - MSB Cascade DAC, MSB S500 Amp, all Shunyata Sigma cabling, QLN Reference 9 speakers. My source is a custom-built Macbook Pro, all my music (a lot of DSD files) lives on an external SSD drive connected to the Mac, and I use Audirvana in Direct Mode to output bit-perfect to the Cascade via Pro ISL. This setup has been working beautifully with no issues.
Playing my DSD files via the XACT didn’t go well
I uploaded a few DSD 256x albums onto its built-in drive. One of the albums played fine, but the rest of them had a fairly loud hiss in the background. It wasn’t the connections - it was specific to those files. I also noticed that my DAC was showing “24-bit/705.6 KHz” in the display instead of what I am used to seeing - “DSD 128x” - for those albums. Technically, 24-bit/705.6 KHz equates to DSD 128x, but in the PCM format.
So then I did some research online, and this is what I found: The XACT doesn’t seem to be playing my files bit-perfect in their native DSD format. Instead, it is probably converting them to PCM first. I also tried my best to find settings in the streamer/JPLAY where I could select Direct SDM (to enable native DSD streaming without PCM conversion), but couldnt find anything. I went through every Settings menu in JPLAY, but no luck.
Any insights as to what might be going on here and how I can fix this problem?
