MSB Palisade: 100 hours in
My Palisade has now been powered for about 100 hours, with the last 72 continuous. Iāve had a few interruptions because I live in lightning-prone South Carolina and Iām quick to unplug things when storms are coming.
For context, my system is an Antipodes Kala K50, Block Audio monoblocks and line stage, Kharma DB-11S speakers, and JL Audio F113v2 subs. I use Wireworld, Tubulus, and Shunyata cabling, along with Shunyata power and grounding equipment. The system is primarily digital, but I also have a Clearaudio Performance SE turntable with an Ortofon 2M Black cartridge, which I use for pure fun.
Before the Palisade, I had an MSB Premier with the matching Digital Director. Before that, I used a Bricasti M21.
One thing I keep coming back to is noise. You donāt always know what youāre hearing until itās gone. Your system can sound great, and then you make a change that seems to remove something you hadnāt realized was there. You sit back and think, How is that possible? How can it be better?
That was my experience when I added the Shunyata CGS and SGS grounding boxes. The improvement was night and day. Moving from the Bricasti M21 to the MSB Premier and Digital Director was another clear step forward. Each time, I would have bet that I was already getting everything my system could give me. Each time, I was wrong.
With the Palisade, I suspect thereās more going on than noise reduction alone. The system sounds more coherent, sorted, clear, clean, and deep. The improvement reminds me of the changes I heard when I moved from my Infinity Betas to Sonus faber Strads, and then to the Kharmas. Changing speakers can make a huge difference. Adding the Palisade has felt comparable. Everything seems better.
A recent example: Brucknerās Seventh with Celibidache and the Munich Philharmonic. The flutes and piccolos sound so pure and lifelike. The orchestra almost ālooksā like an orchestra, with its layers defined and resolved even when the full ensemble is playing. At about 12:40 in Part 1, the hornsāor maybe trumpetsāstep forward with much of the orchestra, and itās glorious. The sound is big, but still fully resolved.
Iāll keep listening and researching what might be behind the improvement. My guess is that it involves some combination of reduced noise, improved timing or lower jitter, and the Digital Directorās BDT technology. I canāt say how much each factor contributes, but the result in my system is unmistakable.
The Palisade is one of the most consequential additions Iāve made to my system and room.
Why the Palisade fit my system
Iām not 100% digital, and I need to integrate my subs. My Block Audio line stage has an excellent built-in phono preamp and a pair of XLR outputs that let me use the subs. I made a conscious decision to buy the Palisade rather than a Cascade because it fit my system and how I use it. The Block Audio line stage is first-rate, and its phono preamp is a big part of that.
If you have a great Line stage, the Palisade is a great choice and a savings from the Cascade.
