Renderer vs Aurender N20
Currently have the Aurender N20 with its word clock slaved to the MSB Discrete DAC. What sound advantages are there if I replace the Aurender with the Renderer module?
There is probably no advantage with sound quality of a Renderer in your setup. The Aurender with word sync is a very low noise input and the Aurenders playback software quality is excellent. In your system, without a Director, the Renderer would likely add additional electrical noise. In a system with a Director this additional electrical noise that is generated by the Renderer is inconsequential.
The Renderer would possibly add a few quality of life improvements however. For example, it would add the ability to play Qobuz Connect without the Aurender in the loop at all. If you do not desire the changes in functionality, I wouldn’t recommend adding a Renderer to your system.
If you were using a server that used Roon for its playback software, I would recommend adding a Renderer and using Qobuz Connect instead. This is because the improvements in the playback software quality in the Renderer using Qobuz Connect over Roon is probably more significant than the added electrical noise of the Renderer in your system that does not include a Director.
Thank you. So the sound quality would equal or exceed Aurender if the Director was in the mix.
I have found the playback quality of the Aurender to be the equivalent of the Renderer, playing Qobuz Connect (not Roon), in any system with a Director. The Director itself will increase the sound quality of any MSB DAC.
Thanks Dustin. I really appreciate your insight.
I assume that the Aurender AES output is preferred over its USB output since the AES can use the MSB word sync clock?
@Dustin_Symanski Thank you
Does this also apply to the Select II with the Digital Director?
Please don’t forget about existing Select II owners!
I purchased my Select II back in 2021 and later added the Digital Director.
It’s a little disheartening to see all the attention focused on the Cascade, with hardly any mention of the Select II.
I really hope MSB continues to support and care about its loyal Select II customers as well.
I did these comparisons:
  • Roon Nucleus Plus B to MSB Renderer over Ethernet
  • Roon Nucleus Plus B to Cascade ProISL via USB
  • Roon Nucleus Plus B to Aurender N20 to Cascade via ProISL USB
  • Roon Nucleus Plus B to Aurender N20 to Cascade via AES EBU with Cascade Clock
  • Tidal and Qobuz direct on Aurender N20 to Cascade via ProISL USB
  • Tidal and Qobuz direct on Aurender N20 to Cascade via AES EBU with Cascade Clock
  • Xact Audio S1 Evo Server to Cascade via ProISL
  • Antipodes K41 serving as Roon Core to MSB Renderer via direct Ethernet using its secondary network port
Ultimately I preferred the renderer with Qobuz Connect for streaming.
@Woo_jin MSB is one of the very few companies in my experaince that ensures all of it’s released products are fully supported (within reason of course) so while I can’ts speak for them before I decided to buy from MSB I did a bunch of research and the universal concensus was you will be in good hands for many many years,
@matthewk Can you share more on your impression on Tidal and Qobuz direct on Aurender N20 to Cascade via ProISL USB vs Qobuz Connect on the Renderer.
Ease of use, functionality, etc.
Does your preferred method of Qobuz connect direct to the renderer allow you to play local files?
@crwilli Sadly Qobuz Conect is streaming only so @matthewk will have to chime in but he might do what I do, Connect for streaming and Roon for local, I also use Roon for Tidal
I’ll add this to build on the options. My Antipodes server offers a few ways to stream Qobuz and my local files. Roon as a default but it also allows me to use Roon as the server and Squeeze as the player. That configuration sounds better to me. It gives me the richness of the Roon UI but s cleaner sound via Squeeze player. Roon/Squeeze has become my preferred configuration.
I can also use all Squeeze but the UI is not good and it doesn’t really sound better then Roon/Squeeze.
I can also run a configuration that uses Minimserver and JPlay. I could probably learn to like JPlay’s UI and its SQ was equal if not slightly better than Roon/Squeeze. But I love the ROON UI and the uptick in SQ that Squeeze provides is close enough to the best so I stick with that configuration.
I cannot compare any of these configurations to Qobuz Connect via the Renderer as I don’t have one. So I read, watch and wonder.
@crwilli that was interesting and tought me something I wasn’t aware of, thank you.
I am fairly lazy but sort of obsessed, my wife uses Spotify and won’t budge, I use Tidal/Qobuz but 500% agree with her that Spotify has by far the better recommendation engine and occasionally just as good SQ (on CD resolution), so I have been leaning towards an Aurender (N50 is my guess but N20 with ProUSB/ISL is still an option) many have suggested the Pink Faun, but that means Roon which I dont (but use to play local files), so I too am learning and want to say thank you.
What about JPlay on the Renderer with the Discrete, as an alternative to Roon for those of us who do not have access to Qobuz? Is JPlay more stable now on the Renderer with the Renderer updates of 2026?
Yes, I do believe JPlay has gone through significant updates since we first started working with Marcin. He has made many changes to improve the playback with the Network Renderer on MSB products. It seems like a pretty bulletproof solution these days. Others will attest I am sure.
Thank you Daniel.
JPlay works great with the Renderer V2. Just need a UPnP server (like minimserver, and several others) hooked on the same network as the Renderer, if you want to play local files.
A worthy alternative to Roon now-a-days. And its a one time $199, vs the Roon subscription. I was fortunate to snag a lifetime Roon subscription the week it came out. One of my better choices. It has taken the rest of the industry a long time to catch up, and/or better, Roon.
Same applies to Discrete and Premier owners.
