I just purchased a Premier DAC with DD. I’ve updated the firmware of both, but they are not syncing. There is no DD info in the DAC’s menu or + sign in firmware version info. I would appreciate any help you guys could give me with this problem.
In your DAC you must only have put Control Link module into Slot A of your DAC and the Pro ISL input module into Slot B and no other input modules in the DAC. This configuration is what puts the DAC in director mode. All input modules must be in the director. The Premier DACs onboard s/pdif inputs and AES inputs will be unusable in director mode, if you require those inputs you must have modules in the Director.
Then make sure the Directors Pro ISL output is connected to the DACs Pro ISL input and the toslink cable is connected to the directors control link input from the DACs control link output.
For more information search our instruction in the support section, we have written and video instructions for the whole process.
If you bought the DAC incorrectly setup then it is likely the previous owner never even got the director working, we have seen a few cases of customers think they were using a director but they weren’t due to incorrect setup.
It appears that you are plugging the TOSLink “control” cable to an SPDIF module in the DAC. The Control module, which is in the Digital Director, belongs in the correct DAC slot. That SPDIF module belongs in the Digital Director.
The DAC should only have the 2 fiber optic only modules. The native SPDIF connections on the DAC are disabled in Digital Director mode, which is why you have that module.
All input modules belong in slots on the Digital Director.
