Great plan, looks more organized than the current setup. Where will you move the Sentinal DD, if you omit the rack on the left altogether? And how about power conditioners/regenerators, audio-grade network switches etc.?
@itoakio Thank you, I am not sure if you had a chance to go over the plans, but there is a Niagra 7000 tucked away in the cabinet.
I have had the good fortune to run several dedicated electrical runs (mostly using Vince’s approach) and tested native 120 vs native 240 vs Niagra 3/5/7000 and my preference is a dedicated 120 circuit to a 7000 and all of the components getting power from it, I have also tried the dual 7000’s and 3 seperate 7000’s but I could not hear any improvements over a single 7000 so that is the configuration I chose.
The DD can’t fit into space so it has been moved to basement, where it gets it’s own dedicated circuit and currently a 3000, it’ also where the streamer will go if I get a Aurender N50, the connection is via AOC fiber.
Ethernet is via the filter approach Vince has highlighted and I dont use any power regen, but there is a 25% chance that the whole panel will be moved over to UPS and as far as audio network switches I tried a couple but I prefer my current 100GB backbone connected to distribution switches (everything other than the connection to the device is fiber)
The plan is amazingly detailed and impressive. Chapeau! You may have addressed this already: are you planning with 2x M500 or is this already assuming 2x Sentinel amps?
@itoakio Thank you, it is possible I might be a touch obsessive, I am designing around the Sentinel amp but ensuring the M500’s will work in the meantime as the unknown is timing.
The other unknown is the Confluence cabling but I am assuming that the connectors will have less than 6" turn radius, and of course hoping the connector is centered.
So the verdict (drum roll) is my wife approved the 0757 Bianco Dover | FENIX materials and solutions for interior design | colour and material. She is still very unhappy with the 3 month estimated duration from cutting the ceiling to the project completion but I will take every gain I can
The TV would be too high for me as well. The fireplace is of course the reason for the height. I omitted the fireplace from my living room when I had my house built. I personally have no use for a fireplace, and we watch a lot of TV. I realize this would be an unpopular choice for many people and will probably hurt the resale value of my house should I ever sell it.
Aside from having to look up, the angle of view with the TV may make it dim with some TVs. Using a bracket to angle it down might be a good compromise if the fireplace must stay.
@Gerard No complaints at all, quite the opposite I agree it is stunning.
I welcome your feedback and thoughts, and you are entirely correct the TV is too high (I had to move it up 1") but there is a saving grace, it’s actually not a TV (in the traditional context). It’s a picture frame (The Frame to be exact) which we only use to show photo’s on. We have a TV room downstairs.
@Mairet My wife veto’d removing the fireplace that we use maybe 5-10 times a year and only for 20-30 at a time, But alas yes the firebox is what is causing all the issues, I can’t fit the director in due to it, I can’t lower anything due to it, etc.
I like the bracket idea as we only need a small angle to adjust, I will start working on that calculation next. The saving grace is we don’t use it as a TV, the home theater system is in the basement and the Frame isn’t even hooked up to the MSB system so while we could watch TV on it we never do, it’s solely for photo’s and art.
