Mconnect Connect
Hey,
is there any way to enable MSB Premier DAC to work with Mconnect Connect application.
This app has Vtune integration that i want the most.
In Player Version in this software there is no way to play Radio Streams.
Or maybe you have any other ideas hot to listen to Radio Streams with MSB Premier DAC ?
For now im testing ROON …
Have you tried MConnect with the MSB Renderer V2? Unless you are casting to some other device prior to the DAC, you would need to try the Renderer V2, which does render UPnP, at least for JPlay it does. It does Roon as well. I don’t think it directly accepts AirPlay, or other casting type function, and no Bluetooth. The Renderer V2 was designed to have the least noise possible. Any of the wireless protocols would interfere with that. Of course, I could not understand everything, so YMMV.
If you have an MSB Renderer V2, it should be worth the $6 to try
Do you use a music server, or NAS hosting your music files, or are you only using internet based music? There are loads of small boxes that will accept Bluetooth/AirPlay/Google Cast and output SPDIF in coax or TOSLink, that could be fed into the DAC.
I was talking about Mconnect Control Series not Player Series.
I was too. To make the MSB DAC do the UPnP part requires the Renderer V2 module. The app you are asking about specifically does UPnP.
The server part would just be to play your own files, not to stream from the internet.
Yes i have rendererV2 and you stil messing Mconnect Control functions with Player functions.
Player works fine - General UPnP control & Google Cast app
to work with all UPnP compatible devices and Google Cast devices.
However Control is not. Im not able to connect to renderer in network environment.
It doesnt even apear after search in devices Tab.
Even if it supports UPnP
*This app will not work if you do not have the mconnect CONTROL hardware embedded device.
So the question was. Is this hardware embedded or not ?
Hello Tomek,
From what I can find looking at their website the “CONTROL” hardware device is their own hardware module. We don’t use the mConnect hardware module so I don’t see this working anytime soon. It seems to be software for their hardware.
